nitrous on 240sx need help
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
hello,i have a 91 240sx with a nx stage one. my only problem is that the bottle pressure is way to low. i beleive it is at 600 when it is supposed to be around 900-1050. what can i do to get the pressure to 900-1050? thanks
-David
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
um, i'm not really an incredibly nitrous-knowledgeable guy, but do you have a bottle heater?
When i used to intern we had very few nitrous installs without bottle heaters.
david200095367
no i dont have a bottle heater, but do u think the bottle is too cold that is why the pressure is so low?
InsanityInc
Uh.
PV = nRTP = nRT/V
So, you can:
1) decrease the size(V) of the bottle
2) put more **** into the bottle (n)
3) heat the bottle (T)
4) change the universal gas constant (R)Disclaimer: I'm not responsible for any problems that may occur from altering the laws of physics.
Unless of course your bottle can't HOLD 900-1050psi, in which case you're pretty SOL.
david200095367
so if i heat the bottle the pressure should go up right? thanks
hek1620
Car: '89 240sx
yes thats why they make them. it keeps the bottle at a certain temperature so the pressure is consistant.
david200095367
ok i will heat the bottle and hopefuly that will work. thanks
david
