Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Wed Apr 05, 2006 7:33 am
That is where the JWT daughterboard comes in. It runs optimized timing for the 11.7, then when you trigger the Nitrous solenoid, it backs timing off, to prevent detonation. Once the microswitch is released, it reverts to the previous timing map. Really very ingenious, and if you are going high compression with spray, there is no better mod. Also, the high compression will allow you to really take advantage of NOx. Without it, your 75 shot will only be about 63, etc.
