Nitrous Install write-up
Booztd 3
Car: 1990 Nissan 300ZX TT
Alright guys, Im feeling froggy, so here's another update
After doing alot of research on the supra forums and guys run big stall auto's with the lower displacement motors, I found that its 100% necessary to spray some nitrous on the transbrake in order to get the turbo spooled and the engine loaded. This is going to help me a TON off the line.......hopefully we will see some 1.3-1.4 60 foot times!
The kit is a Nitrous Express 'Import' EFI kit
I will basically engage the transbrake, and floor the car. Once a little load is on the motor and the RPMS start to creep up, I'm going to spray a 75 shot and this will spool the turbo, and get the car up on the converter (also called flashing)
I am not finished with the install yet, but here's what I have so far
Nitrous Kit
I was instructed to put the nozzle ~6-8 inches from the intake manifold inlet. I removed my IC pipe, flattened it out a bit, drilled the hole, and installed the adapter piece.
Here's the nozzle installed
I fabbed up a thin piece of aluminum to mount the solenoids on
I tapped the fuel for the nitrous solenoid at the regulator. You can see the fitting "T's" off, and the line that goes to the NX fuel solenoid
The bottle is filled, and pressure gauge installed
I still need to mount the bottle, run the line from the rear of the car to the nitrous solenoid, and do the wiring, and test the solenoids out. I'll set some safeguards up on the AEM so hopefully I dont go boom!
Thanks for looking
jdmser
Car: duh
Looks good, I went with the Zex kit. It shaved 2/10th off my 60ft with a 55 shot and that was with it shutting off at 5 psi. That was with the pressure switch not set up. I used my air compressor, a regulator, volt meter, and gauge to set the pressure switch to shut off at 15 psi now and up the shot to 75. Are you just spraying to spool are will you be spraying the whole way down?
Booztd 3
jdmser wrote:Looks good, I went with the Zex kit. It shaved 2/10th off my 60ft with a 55 shot and that was with it shutting off at 5 psi. That was with the pressure switch not set up. I used my air compressor, a regulator, volt meter, and gauge to set the pressure switch to shut off at 15 psi now and up the shot to 75. Are you just spraying to spool are will you be spraying the whole way down?
This is only for spooling the turbo on the trans-brake when the car is sitting still..........Once the car launches I'll have full boost the entire way..........through all gears due to the fact the car is an automatic now...
StricNyne
whoa i had no idea we had this many turbo nitrous cars in our community !! i love the thought of using the zex kit, but i dont even have a running car
jdmser
Car: duh
Both of us are in the Midwest. Everybody sprays out here.
Booztd 3
Well I finished the nitrous install up this week, works well!
To mount the bottle, I came up with the idea of fabricating a plate that would 'close-off' the spare tire well. I'm not going to need it anyways, so I went and got the matial and mapped out what I wanted to do. I basically took a sheet of 16guage steel and had a buddy weld some 1" square tubing on the bottom side of it for support. I then laid that piece of steel in the hatch, and bolted it down, along with the nitrous bottle and the battery. Here's some pics of the setup
Booztd 3
FYI I dont plan on running the nitrous during the launch, its ONLY for spool, so i was not concerned with the orientation of the bottle....
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
looks good man, can't wait to hear your impressions
Booztd 3
Its going to take a trip to the track and probably some stickies, lol
I launched off the transbrake earlier today and it resulted in two very wide black strips of rubber on the ground...im gonna go get pictures, lol
Booztd 3
Just got some pics...and no that stuff that looks like it was leaking was not me.....it was already there....
Notice the big long 1st gear patch, and then a nice healthy shift patch, lol
Eikon
Car: 71 240z, 93 Supra TT
Ricer!
Coolwhip
Vendor
Ricer!
Booztd 3
indeed!
Shocker
Car: 89 240sxHB rb26/30
looking awesome! good luck with those times!
