nitrous express kit wont work need help
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
ok i installed a nx kit and it was working fine. the next day i tried it out and it was not working. i have the nx kit installed with a msd rpm activated switch making it turn on at 3k and off at 7k. so i took the wire that goes to the rpm activated switch and grounded it, and tested the solenoids with the engine off, and both the fuel and nitrous were clicking, so i believe they are working. what could be the problem? can the rpm activated switch go bad? i need your help. thanks in advance.
s13sr20chris
hmmm, im not sure about your problem. i bet if you posted in the ka section my buddy wdracing would help you out.
navysnail
did you close the bottle after you used it? is there enough pressure in the bottle?
david200095367
yes the bottle pressure is fine, and i closed it after i used it.
david200095367
ok i got it to work, it was the wot switch. thanks guys
david
