KADreams »
https://forums.nicoclub.com/kadreams-u27291.html
Wed Oct 19, 2005 1:54 pm
Call up JWT, and tell them exactly what you want. They will build you a custom dry nitrous setup that uses larger aftermarket injectors to compensate for fuel. Their systems are completely controlled by a custrom ECU tune for even fuel distribution, timing retard, window switching, nitrous cut, and even nitrous flow based on RPM. Since no fuel is being injected into the intake manifold, there is no chance for fuel puddling or a nitrous backfire. You won't find a safer system.
If your motor has forged pistons and rods, go ahead and spray the **** out of it.Try out a multi-stage 200 shot and see how you like it.
Example of a nice staged nitrous setup that will allow for traction on the street:
3000RPM: +35HP3500RPM: +65HP4000RPM: +120HP4500RPM: +165HP5000RPM-Fuel Cut: +200HP
