Jostudly wrote:Does anyone here use nitrogen in their tires? I am wondering if it is worth it for fuel economy and better tire ware. Also does a regular tire pressure gauge work with nitrogen? If the nitrogen does go below recommended tire pressure can I use my compressor to add some air or do I need to get more nitrogen filled?
I have nitrogen in my tires as my dealer changed it over as part of their PDI.
You can fill nitrogen-filled tires with normal air if you like. That being said, if you find yourself adjusting your tires continuously you will eventually shift the content of air in the tires to the point that you are receiving little value from initially putting in nitrogen. Therefore, if you are not going to be putting nitrogen back into the tires when they need it, it doesn't seem to make sense to put it in initially.
If you take your vehicle in for oil changes you can see if the shop uses nitrogen. I would think they'd top up your tires as part of their inspection they perform while doing the oil change. My dealer does this for me.
