What is supposed to be the benefit with nitrogen??Scuba Steve wrote:My friend is trying to convince me to take out the air of my tires and inflate it with nitrogen. Is it worth while??? $5.00 per tire. Would it effect the TPMS module???
Steve
It's not a complete scam, but it's not really worth the money either.07Vsdn wrote:there was a long argument on mustangforums.com about this.
long story short, it's a scam.
The idea is that nitrogen is a much more stable gas than regular air. When you inflate your tires with air, high and low temps can increase and decrease your tire pressure by more than a few psi. Try checking your tire pressure when the car has sat overnight and the tires are cold. Then go for a drive at highway speeds for a while and check it again. You'll see what I mean. Nitrogen is not affected by temperature changes so your pressure stays more constant. More consistant pressure = more consistant tread wear. So in other words, yes...nitrogen does do what they claim it does. But, you don't need it if you just check your pressure regularly.weems84 wrote:What is supposed to be the benefit with nitrogen??
Modified by 07Vsdn at 8:56 AM 9/11/2007matt_a wrote:The idea is that nitrogen is a much more stable gas than regular air. When you inflate your tires with air, high and low temps can increase and decrease your tire pressure by more than a few psi.
It's simple chemistry. Even at an 80% makeup, there is still 1/5 extraneous makeup, or in this case just over that, and that extra composition does in fact change quite a bit.07Vsdn wrote:i"We ALL have Nitrogen in our tires. Here is what makes up AIR:
Nitrogen 78.084% Oxygen 20.946% Argon 0.934% Carbon dioxide 0.038% Water vapor 1% Other 0.002% "
But somebody has to stand there and press the valve pin!matttail wrote:...all they're doing is letting all the air out of your tires and pumping in Nitrogen instead so don't let them tell you there's any labor involved.
Very respectable position of higly skilled individuals. Legend has it that the last 10 men that attempted to learn this trade...well lets just say only 3 of them remain.matt_a wrote:But somebody has to stand there and press the valve pin!
Actually it's perfectly fine to top off your nitrogen filled tires with regular air - the idea being this works till you can go back to the place the filled them for you and have then empty and refile your tires. That's part of what the dealer was advertising when I was there - pay once and they will fill/refill for free.Ever Victorious wrote:So what are you going to do if your nitrogen-filled tire gets low? Not all places offer it, so if you're in a rural area, you're going to have to drain ALL your tires and refill them (yes, all, because you don't want one tire running at different pressures than the other 3...).
99.998% of Air is made up of Nitrogen, oxygen, Argon and CO2. Nitrogen molecules are the SMALLEST of these. So Nitrogen molecules are actually NOT bigger than 'air's' like you said.matttail wrote:Nitrogen molecules are bigger than 'air's' so they should leak less (the reason you have to fill up your bike tires again every summer).
matttail wrote:Part of the story with Nitrogen is not only stablizing temp/pressure but that nitrogen is supposed to escape from your tires more slowly. Nitrogen molecules are bigger than 'air's' so they should leak less (the reason you have to fill up your bike tires again every summer).
Costco fills your new tires with Nitrogen as part of the standard service at no additional cost.
I would pay no more than $5 per tire - it's not worth the $10 per tire that my dealer tried to sell me on the last time I was in there. Compressed nitorgen is very cheep to buy - and all they're doing is letting all the air out of your tires and pumping in Nitrogen instead so don't let them tell you there's any labor involved.
Also the air in your tire causes condensation, now if you are a car collector who has… say 50-100 cars and most of them are going to be sitting around for long periods of time. Than nitrogen is an excellent idea, it will not erode the inside of the tires or corrode your rims. Jay Leno has nitrogen in all of his cars but again he has a reason to.matt_a wrote:It's not a complete scam, but it's not really worth the money either.
Thank you for that information. I will make sure when I buy my first flying car I will put nitrogen in the tiresFlatline wrote:Here is a little bit of useless knowledge.....
Nitrogen was originally (and still) used in aircraft tires due to the fact that when the plane is in flight, the air in the tires cools and condenses (and forms ice in some cases). When the plane lands and the tires hit the runway they heat up to tremendous heat (in comparison to the air inside the tires) which would cause the condensation to rapidly increase thus potentially blowing the tire. Nitrogen is much less prone to this.
