CJH »
https://forums.nicoclub.com/cjh-u156783.html
Fri Jan 31, 2014 7:17 am
I have no comment on PFC, but I currently have Nistune in my drift car. I found a shop that can tune it and have gone through iLL Garage out of Chicago for years. I don't mind the Nistune, but iLL recommend i go with AEM instead. I didn't have the cash at the time, but it is a goal of mine to switch over. I did a full wire tuck and removed sensors I felt I didnt need. Nistune requires a couple sensors that AEM doesn't, so I couldnt make my harness as skinny as I wanted. The most noticeable thing about Nistune is its throttle catch on rev fall. If you slow down and down shift, the car works as normal. If you are at higher RPM and go into neutral and let the car fall to idle, it will die. Example, if I'm accelerating from one light and I'm at 4k RPM and the light in front of me turns red, I shift into neutral and left foot brake while lightly pumping the throttle to slowly bring it down to the resting idle. If I just went into neutral the car would die.
