virus77 wrote:Open nistune twice so you have two instances running, one with the RB25 address file and maps. On the other nistune screen open your RB20 maps and address file and copy the main maps and perimeters from the 25 to your 20. This should give a good base. What mafs are you going to be running? If you plan on running z32 I would load the Z32 fuel and K value and use the RB25 timing maps.... this is what I did using a z32 ecu, z32 mafs on my RB25 and it was really good base to start from.
Ok... So base RB25 maps are readily available from somewhere? Keep in mind i wont actually ever have the RB25 ecu. To start out I'll probably run the rb20 maf since its the same as the rb25 if im not mistaken (what HP does it max out at?). Although i almost should get the z32 maf, its a pretty cheap upgrade.
As an aside, do you know if i can run the injector sub harness from the rb20 on the 25? Ive heard you cant.
