Nistune peeps
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
Hey, got the nistune soldered in and getting ready to download the basemap slightly altered for the larger injectors. I just wasnt sure if the board comes with a base map loaded on it?
And dose anyone have any advice?
Thnx Shri
mbmbmb23
I can email you a slightly "tuned" basemap you can mod to suit your needs if you'd like, its a rom I pulled from an "impul tuned" ecu that uses oem injectors and maf. You'll have to change both of those values to suit your needs and remove the speed cut......all of which is easy to do in Nistune. Let me know.
-m
XTCshri2222
yA that would be great, my email is [email protected]
Buddyworm
It should. They generally load a base map onto your board based on the part number you gave them when you ordered.
jt15833
Car: 95' 240SX
i am on
CA18DETSR20 turbo w/ K&N filterStock injectors and mafFMIC, 3" exhaust
You think that map would suit me alright?
mbmbmb23
BIN sent.
