Nistune or PFC for S14 w/ RB25DET
GSDKinked
Car: 1997 240SX LE
Alright I know the first thing you guys are going to say is for me to search for this topic. I have and read them all and still don't know what to pick......
Goals:
400whp Streetability (not daily driven but driven often)Responsive
Has:
GT35R w/ 38mm EWG set up (stock mani)top feed fuel railRB25 ECU (Also have Z32 TT ECU sitting next to me)Greddy Intake mani with Q45 TBGreddy FMIC
I've had Nistune before when i had my SR. I liked it alot, never had PFC and I'm being told with my power range I should use it. However, I see otherwise in the Aussie forums, and they know their $h#t.
What would you go with?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
which ever is cheaper.
Funktown240
Car: 93' 240sx
You should go with something smaller. . . . .like a 3071 or 3076 to be more responsive. Even the smaller 3071R should make 400WHP with no problems.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
If you already have experience with Nistune, I'd say go with it since it will probably be less than the PFC.
If you were unfamiliar with Nistune, I'd recommend PFC with datalogit software.
WhatsADSM
Car: 1998 240sx
Nistune
bobob729
if you have your experience with nistune then i would go with it im going nistune on my z and my 240 and it will not be as complicated as a pfc. At least in my eyes.
stevespeed
Car: RB-Swapped S13, FTW
I have heard great things about nistune, like 0 limitations until you start shooting for insane power numbers.
TwoJayZee240
Car: 93 RB25 powered hatch
I had the same question you did. I went with nistune.
I am running Nistune on my RB25 and I love the product. I Baught a Z32 ECU and sent it to Andy at Autovaughn Performance in Tennassee. Great guy and he answered all my questions About Nistune. From the beginning i couldnt see paying $2000 for AEM EMS or $1200 for PFC especially cause not one tuning shop 200 miles around me had ever tuned a RB25 before let alone used PFC before. So then My only choices were Nistune or Megasquirt. I didnt want to make the megasquirt board and buy all the coils and crank triggers and what not so i went with Nistune.http://www.autovaughnperformance.com/
Reasons to go with Nistune. 1-You can go to any junkyard and get a z32 ecu anywhere from $40-$100 I picked mine up for $50. YOU CAN GET ANY Z32 ECU! IT DOES NOT HAVE TO BE FROM A TT OR A STANDARD CAR! It dosent matter because you take the read only memory chip out and install the nistune type 2 chip. Try to get a ecu from a 1990-1994 that are 8 bit ecu's, they are a little more nistune freindly. 1995-1996 ecu's are 16 bit and are a little more advanced and need a type 3 more exspensive board.
Posatives to having a Z32 ECU - Keeps the RB25's VVC.
Negatives are that you have to switch around a few wires to make it work. No big deal
So I made a call to Andy and i needed a wideband and Nistune supports a ton of them. I opted for the Innovate LC-1. At $229 you cant beat the price and it was rated one of the most acurate widebands and most of all Nistune can see it in their program.
From Autovaughn for just the Nistune product for everything it came to $495 and for the package for him to install it and make sure everything works it was $505 so sent him the ECU for him to install the chip. For $10 more it saved me the time and agravation. So that came with chip installed consult cable and tuning lisence software.
I have been tuning it myself gradually. Im running 13lbs of boost on the stock turbo, with Afr's at 11.8 under boost.
So in the end $505 + $229+ $50= $784. it was still cheaper than PFC and i can tune it from my Lap Top unlike PFC u would still have to buy the datalogit for the PFC and a Wideband if you didnt already have one.
Thats my opinion and choice. I plan on running a HX40 in the spring with a Ford Lightning MAF and 740cc injectors and best of all nistune supports it!
GSDKinked
Car: 1997 240SX LE
well see....lol I got this 35R for like nothing....so I had to put it to good use
Plus this 240 is just the guinea pig....but thanks for the heads up. I guess when this thing is finally running I'll use this Z32 TT ecu and tune via nistune.
lazyboi444
Car: 240sx Hatchback
Last time i checked i had seen a thread where they were thinking about putting a RB25 nistune board into works. Spite the difficulty involved. Let me see if i can find it.
Found it, its on their site. But i'm not sure if there has been a update on whether they started it or not.
Modified by lazyboi444 at 8:24 PM 12/15/2009
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Tuning via laptop vs hand held controller. Your choice.
TwoJayZee240
GSDKinked wrote: I'll use this Z32 TT ecu and tune via nistune.
You can use any z32 ecu, it dosent have to be TT. Mine was a NA 5 speed, then take the read only chip out and put the nistune in its place, You will be running a Z32 TT address file anways. Then just copy over the RB fuel maps to the Z32 image files.
Xylemer
If you guys wanna give me a call, I may be able to answer some of your questions.
Feel free to call, text or email.
(615) 796-6234
[email protected]
Thanks,
Andy
Ramius83
Car: 1995 240sx SE
Xylemer wrote:If you guys wanna give me a call, I may be able to answer some of your questions.
(615) 796-6234
[email protected]
Thanks,
Andy
So, how would something like this work for the RB26 equipped vehicles shooting for around 600WHP or so?????
Type 2 board with double Z32 MAFS??????
Modified by Ramius83 at 4:26 AM 1/28/2010
Xylemer
That or you could go with the Ford Lightning MAF
virus77
Car: 95 S14, 71 240z, 97 e320
+1 for nistune.... love mine
