NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Jul 20, 2003 9:48 am
i believe you can gain acces to it if its on a hoist and you remove the oil filter it is totally accessable. I am not 100% sure you may have to remove one other thing. why are you replacing it is it due to a code? if so how long it takes for the code to generate after clearing it is important. if its immediate it is a circuit failure. if not it could be fuel octane level. in the circuit case if there is a sub harness to yours it should be replaced as well.
