SlowBack »
https://forums.nicoclub.com/slowback-u29200.html
Sun Jul 24, 2005 7:46 am
Hey, Nistech, I think you're one of the greats and I greatly appreciate your generosity toward myself and fellow forumites.
The problem that I'm having is that I dropped my transmission to put in a pilot bushing (didn't do it during the 5spd swap 6months ago D'oh!).
Well, I installed a pilot bushing (couldn't get that auto adapter bearing off, but I did grind it so it's out of the way), I installed the clutch, pressure plate, but can't get the transmission to go all the way in.
One thing I noticed is that the end of the clutch alignment tool did not go into the pilot bushing smoothly, in fact, it took quite a bit of force to get it in and out.
The transmission only has about an inch or so to go before it's in, but I can't seem to get it to go.
Any suggestions? Also, how far back should the pilot bushing be inside of the crank? Should it be a pressed fit all the way to the back? How much of the transmission input shaft actually goes into the pilot bushing?
PS, I did search and came up with a thread where you said the bushing can mushroom and cause fitment problems, but I'm wondering if this would be the same issue in my case.Thanks a bunch in advance,Matt
Modified by SlowBack at 11:46 AM 7/24/2005
