Nistech Help!!!
Schfifty-5
Car: CArs
Few questions for you. I have a 93 S-13 with the HUD and digital speedometer. Well, the speedo doesn't work as well as the hazards and blinkers, no interior lights on the dash and the HUD doesn't work. Everything else in the cluster works fine. Tach, fuel, temp, all that. I pulled the cluster and everything is plugged in and there was no wire cuts or chaffing. Any ideas on what to look at next?? Also wondering how to get the pop-up headlights to come up half way? Is there an adjustment for that? Thanks for your time and help!!
Brian
droll
Schfifty-5 wrote:Also wondering how to get the pop-up headlights to come up half way? Is there an adjustment for that? Thanks for your time and help!!
Brian
http://www.240sx.org/faq/artic...p.htm
NISTECH
I think you have more then one problem going on. You blinker adn hazards would have to do with the hazard switch likely. But you need to do a thorough fuse check first make sure none are blown. You may have a dead HUD conrtol unit as the reason for the speedo.
Schfifty-5
Car: CArs
Thanks. I did check all the fuses, but I'll check the hazard switch for a good conection.
Any ideas on the pop up lights??
NISTECH
That is a mod I am not sure how its done. Search 240 tech section for "lazy eyes" I think thats what they are calling that.
Altiman94
Car: 1989 Nissan 240SX
the guy above posted a link for you to check out.
NISTECH
Altiman94 wrote:the guy above posted a link for you to check out.
:confused:
nametakennow
Car: '06 MINI Cooper S
He's talking about droll's post. It's a pretty simple process, I read it and I don't even have a 240 :(.
Schfifty-5
Car: CArs
Appreciate it. Found the link finally. We'll give it a shot in the garage later, I'll drop an update!!
