amolao »
https://forums.nicoclub.com/amolao-u11541.html
Wed Nov 30, 2005 11:58 am
No, all I had to do was torque the valve cover a bit more....find a way to clean the spark plughs and wires without taking the spark plugs out. If you do, all the oil sitting there will drain into your cylinders and your car will smoke for a little bit, no major damage though....It should be a quick check, on how tight the valve cover is. I left mine kind of loose because even if you torque the !@#! covers by the specs, the threads tend to get damage anyhow.....
