nissan vk45dd engine
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
acoo1allan
Car: nissan cima
hihave purchased a vk45dd engine im looking for a workshop manualmainly wiring & fuel system controlsregards allan
confedup
Car: 240sx
Why post in this forum?
Raxephon
Car: '04 RX8...for the moment...
confedup wrote:Why post in this forum?
Maybe because its the VH/VK section?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
lol owned.
Kirby260
Car: Datsun 260z
Hi Allan,
I don't know anyone that has managed to get their hands on VK45DD, which is quite rare, due to having one production year.
Can you take some detailed photos?
I'd be interested to see the injectors, High-Pressure fuel pump, heads and that sort of detail. From this we might be able to identify some of the similarities to the VK45DE.
Cheers.
Raxephon
I found this:
Quote »
The VK45DD is the same as the VK45DE but adds an direct injection fuel system. This was Nissans first V8 with direct injection. It produces (officially) 280 ps @6000 rpm and 451 Nm @3600 rpm. But it has unofficially over 300 ps. It has a compression ratio of 11.0. Direct Injection may refer to: a music recording technique more commonly referred to as Direct Input. ... Direct Injection may refer to: a music recording technique more commonly referred to as Direct Input. ...
It was used in the following:
* 2001- Nissan Cima[/quote] Here: http://www.nationmaster.com/en...K45DD
So, assuming the statements on that site are correct, shouldn't you be able to use a factory service manual from a VK45DE powered Nissan/Infiniti?
acoo1allan
Car: nissan cima
no probswill take some photoeswhats you email addresscall me 0409196778
Kirby260
Car: Datsun 260z
kirby (dt) nankivell (a) gmail (dt) com
guderiancol
Car: Patrol Y60 TB42 1992
Sentra B13 1600 aut 2007
Nissan Versa (tiida) 2007
acoo1allan, what about your engine, Is it runing? i want to talk with you iam very interested in that engine, info, parts, ecu, etc, email me, [email protected]
Lourens
Car: Building a 4x4 with Nismo engine ( GK 5 } Nissan Safari Under Carriage with Nissan Patrol Body
Hi Guys.
Have that same engine. Also looking for info on electronics. When Nissan programmed the computer with the key, is there a way to override it or to bridge ports. Building a 4x4, using a Safari under carriage. E-mail: lappies1970@gmail .com
Return to “VH45DE / VK45DE / VK56DE Forum”
