If you have power at the fan motor, then your relay is OK.
For reference, the relay is at the left side of the fuse block.
Check both of the 15A fuses for the blower anyway if you haven't already.
If you ground the other terminal at the motor, will the fan operate?
I know its kind of up in there, and no so easy to get to.
If it won't run, the fan motor is faulty.
If it does, you need to take a look at the ground coming from the front air control (fan switch)
Look at the ESM here:
http://www.nicoclub.com/FSM/Versa/2012/Hatch/MTC.pdf
Pages MTC-27, and MTC-35 to 38.
