Nissan versa Service Issues
gupta.sachin25
Car: Nissan Versa 2009
Hi All
I have Nissan Versa 2009 Model. Bought it 1.5 years back on 52K. Current Milege is 66K.
I did all regular oil change service. However, never did some complete service. Recently I find some issues with car
1) Engine making some noise and being felt heavy
2) Type Air Pressure warning light comes on and off randomly.
Was just wondering whether I should go for some major service and where should I go.
Should I go for Nissan Dealer Service or some other place.
I am new car owner and don't know much about car maintenance.
Thanks
SG
unijabnx2000
Car: NX2000
Is it throwing any codes/cels?
gupta.sachin25
Sorry did not understand ur Q
RobJordan
Car: 2011 versa 1.8 Hb 6spd
1. I would take into dealer for service engine soon light or what they call a check engine light. Slow or sluggish engine can be a list of things i would take the vehicle for recommended services always. This web page should give you the services you should have had and what mileage.
https://owners.nissanusa.com/content/te ... -guide.pdf
2. The tire air pressure light or flat tire light with a ! in the center. Means that you need to check your air pressure in tires. Typically we inflate the tires to 36 pounds of pressure. This allows for cold weather to not lower tire pressure as much as cold air contracts the air molecules making the pressure less. and during warm days you would fill the tire pressure so its expanded the most as to not over inflate.
redarrow88
Car: Nissan Versa 2008
Nissan Versa 2008
I lost the gas cap and drove 200 km
Service engine soon came up after that
Put the new gas cap in - light still there
It takes from 100 to 300 engine starts to clear out the sign itself
Went to service in 2 min they hookup scanner and clear out the sign
