nissan versa/latio cvt tranmission oil...
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
holdgee
Hi all
Does any one know what mileage in km or miles should you change the CVT transmission oil???
I do not have a consult II device to check the programming. For the versa 2007 they say that the tranmission oil can be replaced by using the consult II and checking the CVTF deterioration date as below:
CVTF DETERIORATION DATE”More than 210000:It is necessary to change CVT fluid.Less than 210000:It is not necessary to change CVT fluid.
What conversion this number relates to in KM or Miles???
Is it also safe to open the CVT transmission oil dip stick to air????
alonsorules8
Car: 2008 Nissan Versa SL HB
In the USA Nissan recommends replacing the CVT oil at 60,000 miles.
To answer your other question Nissan has the CVT dipstick locked to keep contaminates out of the CVT and requires a special tool to unlock the dip stick and to keep us form putting regular ATF fluid in it.
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
100,000 km
holdgee
thanks alot !!!
Return to “Versa Technical Discussions”
