Nissan versa help
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Kapowerful
Car: Nissan Versa hatch back 2009
I have an 09 versa hatchback couple things wrong with it
since I bought it a year ago been putting it off and finally
ready to fix these things.
Gear indicator/ gear shift panel is out of place I would like to know
how can access it to put it back In place, also the shift stick is faded
And would like to know how to remove it and put a new one.
No antenna Radio works fine in the LA area but as soon as I'm out by the
IE I get no signal I haven't bought an antenna cause I wasn't sure if it's just
as easy as screwing it on or if I had to do some wiring of some sort.
Leather on door arm rest is ripped up I would like to know if that's fixable?
If you can help me on any of these it would be great thanks. :)
Return to “Versa Technical Discussions”
