Martini wrote:Good information!
Curious, what are optimal driving conditions? What tempatures are best suited? Would it not be best to let the car heat up in a garage (assuming proper ventilation of course) before driving?
Yes and no. It's better to start your car from being inside a garage on a cold day, as the engine will start at least a couple dozen degrees warmer than outside. However, letting the car IDLE up to temperature nets you precisely 0 miles per gallon for the whole time you let it sit there. It's a catch 22... suffer decreased fuel economy while the engine is cold until it warms up, or warm it up but suffer decreased fuel economy by burning fuel and not moving the car with the energy created.
As a point somewhat of a sidenote to achr, I also tracked my mileage fanatically when I had my V. CVT Versas may have an extremely wide range of fuel economy under different conditions, but 6MT Versas are much more controlled. Under the worst conditions, I got 28 MPG, and under the best 34 MPG. It almost always got 30 in normal conditions, with only a +/- 0.5 MPG fluctuation in average from tank to tank.
