Nissan Versa Audio System Questions
X-TECHNO-X
Car: Nissan Versa Hatchback 07
If you have any questions about Audio system of nissan versa 2006-2007 post them here.
I Have a nissan versa 2007 and my question by the way is that how we can take the head unit off of the car? I dont want any scatches on my car though.
I read the manuals and found nothing on them. No where else in the forum said anything about the head unit!
marleyfan
Car: Black Versa SL, CVT. Tech Package, 35% Tint, Window Visors, Spoiler
I think you have to place the same post in a minimum of 4 different threads at the same time in order to get a response. Better post it one more time.
idunno22221
Car: 2007 Nissan Versa 6Spd
if your taking the head unit out. you need to pop off the top piece above the head unit..like that whole piece. then you can unscrew the part of the dash that is covering around the head unit and temp. controls..after you do that. there will be 2 screws on each side of the head unit..take them out and your head unit should be out!
let me know if you need anything else,idunno22221
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
zerothread?id=215926http://forums.nicoc ... ?id=204732
Couple threads on this topic.
I think I still have a full write-up, written by our resident audio nerd, in .PDF format. Email me if you would like me to send it to you.
X-TECHNO-X
Thanks. I have removed the head unit and now I need to change the front door speakers. does anybody have any ideas how to do it step by step?
Ever Victorious
'73 AMC Hornet
X-TECHNO-X wrote:Thanks. I have removed the head unit and now I need to change the front door speakers. does anybody have any ideas how to do it step by step?
Sent you the writeups.
X-TECHNO-X
thanks so much! that really helped
marleyfan
EV, could you either send them to me too or else post them. thx
Ever Victorious
'73 AMC Hornet
marleyfan wrote:EV, could you either send them to me too or else post them. thx
I'll send them to you. The articles team has a hold of them... but they haven't gone up yet.
X-TECHNO-X
wow I got a big problem with installing the new speakers in the front door! the surrounding plastic of the original speakers is stick to the speakers and I cannot take the old speakers out of the plastic and put the new one inside it and then screw the whole thing in the door! do you know how that is possible? I thought maybe I need some extra wood or something to screw the speaker in it and then screw the wood to the door...
Ever Victorious
'73 AMC Hornet
X-TECHNO-X wrote:wow I got a big problem with installing the new speakers in the front door! the surrounding plastic of the original speakers is stick to the speakers and I cannot take the old speakers out of the plastic and put the new one inside it and then screw the whole thing in the door! do you know how that is possible? I thought maybe I need some extra wood or something to screw the speaker in it and then screw the wood to the door...
I never played around with the audio system in my V, those were actually written by Jemdawg. He is our Versa Audio Nerd. You might try emailing him.
gavin
Car: 2007 versa s
I had the same problem replacing the speakers you can take a scroll saw and cut the old speaker out of the bracket just cut the magnet out and the fin pieaces out and you sould be abel to fit your new one in and screw them to the plactic braket and then instan the bracket back in the original hole
XterraVersa
Car: 2002 Nissan Xterra
Nissan 350Z Nismo
Can you send me the speaker write ups?
Thanks
X-TECHNO-X
XterraVersa wrote:Can you send me the speaker write ups?
Thanks
I sent them to you to [email protected]
X-TECHNO-X
Thanks for all the help.Im going very good so far.I just broke some of the door panel tabs. do you know where I can find them to buy?
XterraVersa
Nissan 350Z Nismo
Check the parts stores...or your dealer. Fasteners are rarely marked up.
X-TECHNO-X
I posted this question in Nissan's Battery section but it seems no body knows the answer and its been there more than a couple of days... so i just decided to RePost it here,
I am currently using a Kenwood KAC-9152D (900w RMS) and it needs a 75 AMPs battery which is dividing 900w by 12v. do you think the Kinetik HC Power Cell model HC600 is enough for it? I was really shocked when I saw that they can hold 850 Amps!!! is it true ?! it means that it can run a 850 x 12 = 10200Watts amplifier!!!btw im using this formula >> Power(watts) = Volts(v) X Current(amps)AND Another question, do you recommend buying from ebay? coz it costs about $100 on ebay while it costs $199.00 on stores
