Nissan to replace my Brake Pedal?!
All things Altima Coupe.
Mr.HacKeR
Car: 09 Altima Coupe 3.5
Hello guys
I just wanted to know if any of you had this "problem" (if you may call it that) before. I took my A/C for the regular maintenance (service), I had no problems with the car, I just told them that the brakes were noisy. Today they called me and told me that they need to change the brake pedal (under warranty) because it's noisy?! :rolleyes: Ya the pedal was making some strange noise (loud and noticeable), but do you think it is an indication of some other thing? Is it a regular thing to replace a pedal? I've never heard of such thing before..
Mr.HacKeR
Sorry, just realized that this has been discussed before!
Admins, could you please erase the thread
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
You can delete it yourself. Click edit and then top left there is delete post.
Mr.HacKeR
hmm.. I guess the "delete post" is just available for a specific time after you write the post.
thanks for the help though!
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
No need to delete! Post the other discussion here so the topic can get some more visibility for the future.
Mr.HacKeR
All the related threads can be found here (1st page)
http://www.google.ae/search?q=altima+co ... 66&bih=610
Mr.HacKeR
**UPDATE::
I took my car to the dealership today, they said they were going to replace the brake booster, and that it would take 2 days to finish.
I asked if it was urgent, they said it is better to do it now because my car is still under warranty. This is a an expensive fix, it would cost about $1,700.
Bottom line is this, if you think you have a problem with your brake pedal (noise) and if your car is still under warranty, then don't waste any time and go fix it before it's too late!
SHIFT_COUPE
Wow! Thanks for the update. That's a new one on me!
Can you tell me a little more about the noise?
Mr.HacKeR
The noise sounds like an old spring, and a plastic ticking noise. I also noticed that there was some gap in the brake, that means you have to hit the brakes a little more for them to stop the car or you hit the brakes a little bit (1/4) and the lights don't even come on. I thought it was a normal thing, I didn't like it for sure and I asked the dealership to check them for me many times, but now luckily there really was something wrong with the brake booster. I should pickup the car later tonight.
