Nissan Tech Hellllllp!1!!!!!
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
Ok sorry to be so urgent about this, but its pretty dam hot in Ca at the moment and I got a problem here. I posted this question yesterday and havent really heard anything yet so, I thought I would try again.
I have a 95 240sx SE with power windows. Both windows and the moon/sun roof stopped working yesterday. None of the switches do anything, no motor sounds nothin. I check the fusible link and that is fine. I checked voltage acrossed the terminals and the power side reads battery voltage (above 12 V). On the ground side I am ready 1.2 VOLTS ?????? I assume something in the bottom of the fuse box under hte hood is the problem.
Do you agree/disagree with this assesment. Also if it is the fuse bos, how do I remove it so I can check which wire is shorted.
Thanks
Jason
Altiman94
Car: 1989 Nissan 240SX
Check all of your fuses to see if any of them are blown. There are som eunder the hood and someunder the steering wheel. More than likely thats the problem.
hybrid_flyer
nope thats not it. The isnt even power goin to the ACC fuse. I found this out when i tested voltage at the relay. So I guess I got to pull off the entire fuse block and trace back from there to the ACC switch on the sterring coloum (sp). dam i need food i cant even spell now lol.
Dattebayo
what about the battery's connection? Is it loose or is there corrotion on the inside of ther terminals?
NISTECH
hybrid_flyer wrote:.
I. I checked voltage acrossed the terminals and the power side reads battery voltage (above 12 V). On the ground side I am ready 1.2 VOLTS ??????
Jason
What terminals?
NISTECH
check your power window relay in your left kick panel. it feeds both cicuits.
hybrid_flyer
its not the relay, there is no power from the ACC (green) wire when the key is on, hence the problem. there is a 7.5 amp fuse in series with this wire, and that is not getting power either, so its got to be the connection at the back of the fuse box
hybrid_flyer
ok got it fixed the wire was loose in back. Situation fixed and everything will be fine
NISTECH
BTW I am about an hour and a half east of ya. In sac town.
