Nissan Skyline R32 engine swap...???
BigC_1988
Car: Nissan Skyline R32
I have a Nissan Skyline R32 GTS (non turbo) that has a RB20DE engine...I want to swap the engine with a RB20DET or RB25DET...I need help ! What are the steps that I have to take and are there things I have to change for example differential, fuel pump ect...
Carl H
this is not hard just remove the old engine and bolt in a rb20det or a 25det...wiring is diffrent on the 25.
BigC_1988
When doing this should do I have to change anything? Like fuel pump differential ect??? Or just "plug and play"?
TurboSouthAfrican
Car: 1997 240SX w/RB26
BigC_1988 wrote:When doing this should do I have to change anything? Like fuel pump differential ect??? Or just "plug and play"?
I was told that it is not just a "plug and play" swap. For starters, I would replace the pump as an 25 needs more fuel but as far as wiring goes, I was told a few things have to be changed. ECU of coarse which would come with the 25 motor anyways.
Good luck.
BigC_1988
I also hear my differential is to "weak" for a turbo..?Is that true?? Or will it be OK if I keep it on low boost (5 psi)
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Your diff will be fine.
DJButton
Car: 2010 Nissan 240sx
A limited slip diff wouldn't be a bad idea and there will be some wiring differences, but swapping in an RB20DET should be freakin cake.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Yeah, the 20 is a piece of cake... as long as it gets shipped in good condition...
(mine wasnt)
Only about 10 wires to wire up, also use the KA LOWER harness :-)
trying to spice all the wires for the rb harness would be a pain..
Also, ka harness plugs directly into the alternator, and starter, you just have to splice the oil sensor in using the rb plug..
Cjmartz2k
Car: Hunting for a '89 GTR now
Dude, did you read the original question? He wants to swap an N/A RB20 in a SKYLINE for a RB20/25det.
Get yourself a walbro instead of trying to track down a gtst pump. Also, if you going to go to the trouble of the swap, I would go RB25. I would run down stock GTR's all day long when I put just a stock turbined 25 in mine.
BigC_1988
OK, I'm done with the swapping part now. Now it's on to the wiring? If there is anybody out there that has done this before, please HELP
BigC_1988
I have a RB25DET Series 2 BTW
