S133P3R »
https://forums.nicoclub.com/s133p3r-u103576.html
Tue Mar 17, 2009 12:30 pm
a few solutions that come to mind...
1.*CHEAPEST* buy the 6" line that connects from end of hardline to slave (or dampner box, if not removed) and use it to make up the difference between the master and hardline... not sure if there will be any negative effects like softer pedal or not. there will just be an odd lookin line. this should be available at most parts stores.
2.*DIY*buy new hardline, rent/buy tube flaring tool & tube bender... and make your own... although this seems pretty difficult, i made a new one for my car cuz all the bolts stripped from the master cylinder down to the slave. google "tube flaring" and use that as your guide, its easy if you take your time and measure carefully. i think the threads on the cylinders are "M-10".
3*BEST* buy a Stainless steel line that goes from the master cylinder directly to the slave cylinder. i just bought one of these even though i bent my own custom hard line, will use the SS instead. these are commonly used by people doing an A/T to M/T swap...
any questions, just mark a #followed by the question regarding that method.... GOOD LUCK!
