Nissan sentra radiator fans doesnt work
EugeneSentraSTI
Car: Nissan sentra Sti 200 (actually a sunny shaped sentra )
HI
what could be the problem if my radiator fans would switch on? i need to turn the m on manually with a wire,
i tested the temp sensors ans but they all seem to be fine?
id really appreciate if you guys can tell me what to do to fix the problem..
NISTECH
year of car?
EugeneSentraSTI
ITS A 1994,IN SOUTH AFRICA ITS CALLED A SENTRA BUT ITS THE NISSAN SUNNY THERE BY U GUYS,, SR20DE MOTOR
NISTECH
nope its called a sentra here in the US too. You need to check the fuses and relays. The relays will be under the hood near the battery in a black box. Find your cooling fan relay and you need to test it with a volt meter for power. Should have 12 volts on 2 of the terminals. Also look over the fuses inside the car under the dash. Not sure if your R/H drive or L/H drive. If its L/H drive the fuse box is in the lower part of the dash behind an access door near your left Knee. If its R/H drive it will be in the same spot near you right knee.
EugeneSentraSTI
il go and try it thanks,, let u know
