boriquaS13 »
https://forums.nicoclub.com/boriquas13-u55323.html
Wed Aug 08, 2007 3:10 pm
What year sentra is it? Obviosly 96 and newer being its obdII. Does it have coil on plug, depends on year. Do you happen to know what the symptom was before changing the cas sensor? No start? Check Eng Light?Multiple cylinder missfire could be caused by many things ie: vacuum leaks, bad Ignition wires or Ignition coils, egr stuck open if applicable or maybe they could have installed the cas incorrectly. Dunno, more info would be great!
