Nissan Sentra 2004 suddenly having a series of weird issues
darktremor
Car: Nissan Sentra 2004
First of all I'm a new member here and glad to have finally found a forum that isnt having a dead Sentra section. Second of all, I am not a car expert.
My dad has a Nissan Sentra 2004 with a 4 cylinder 1.8 litre engine that has done 258,333. Recent repairs were track-rod ball joints for the front right tire, alternator belt, engine mountings, drum brake shoes, battery. The only repairs myself I did was battery and alternator belt.
We had recently done these repairs for our 12 hour road trip to Dubai, and after doing all of these repairs car was running almost perfectly except it would stall but VERY rarely(no CEL light back then so we couldn't check). The car was acting brand new, and didn't cause us a single issue during our travels.
The issues started recently after a month of our travelling when one day when my dad started his car idle speeds started fluctuating, and the moment he would turn on the A/C, it would get worst. The car feels like as if its losing power, and stalls. I couldn't pull any codes because the Check Engine Light randomly disappeared after it was on for some time.
The car also has this problem of stalling in the middle of the road when the AC is on and sometimes it even stalls even when the AC is NOT ON. Is this a faulty Alternator issue? I am guessing this because whenever we turn on the AC and the car is stopped the lights in the car are flickering when we look closely and it struggles to pick up speed after stopping in a red light. It also doesnt blow cool air when idle but when we are driving its fine.
The final problem is that my dad sometimes has to now keep his foot on the gas pedal to start the car.
Now for the idle speeds fluctuation part I know I have to clean IAC and TB, but I have no idea where are these located in this car and Google has no info on this. If anyone could tell me about this I would appreciated it. My dad is taking his car for full inspection to see what is faulty and what is not so that the car doesn't bother him anymore, but me and him would like to know how much currently damaged his wallet is with the issues we know.
Thank you in advance for any responses I get.
benissimo
Car: 08 Nissan Sentra S 2.0 MR20DE
Sorry for such a late reply, did you determine the issue? I had a similar alternator issue that would dim lights, make a dip in rpm. But I think you are right to check tb and IAC. Also check MAF (mass air flow) sensor. I drove across US and the car would stall coming down to idle at a stop. Then the car didn't want to start, and I had to give it gas to start, eventually it got so bad I had to give it gas at all times to keep it on. This ended up being a leaf stuck in my MAF sensor (got past the air filter and came through intake). It is inline with your air intake. Mine is also conventient - only 2 Philips head screws hold it in. Your throttle body is also around here- just before your intake manifold. If you start taking apart intake from your airbox forward, you will see the throttle plate inside and the cables that hook it to your gas pedal. IAC I don't want to tell you, because my 2008 is a different generation sentra.
But click the link service manuals at the top of this page and you will find the service manual for your car year. Very helpful and free
