xyster »
https://forums.nicoclub.com/xyster-u1869.html
Tue Mar 30, 2004 2:01 pm
I'm assuming you have a CA18DET? If it's stock, it most likely doesn't even have a BOV. Try cleaning out your AAC valve. If you look at your intake manifold, on the right side there is an assembly of a couple cylinders and plugs bolted right to the manifold. Disconnect the wires and hoses to this assembly, and undo the 3 bolts holding it to the manifold. Have some RTV on hand in case you mess up the gaskets. Take this assembly all apart, being careful not to lose the tiny springs and pins that are in it. Clean the whole thing thoroughly with brake cleaner or something, let it dry, and put it all back together. That helped my idle smooth out a lot.
You could also check your timing. You'll need a timing gun and a spark plug wire. Pull the coil pack out of cylinder #1, attach the booted end of the plug wire to the plug still in the cylinder, pull the red rubber boot off your coil pack, and tape the other end of the plug wire on there so that it is touching the metal pin at the end of the coil. Hook your timing gun to your battery, and idle the car. You should now have a coil pack laying in the engine bay with a plug wire running from it to the spark plug. The timing gun clamp should be clamped around the plug wire. Wait until it gets to its warm idle (850 +/- 50), and set the timing to the next to last notch on the right on the crank pully. Adjust the timing by rotating the Cam angle sensor.
How's it idle when warm? Does it idle smooth at 850ish? If not, you may need to adjust your idle. Disconnect the aforementioned AAC valve, and turn the 10mm bolt at the back of the whole assembly you cleaned earlier until idle reaches 850. One way you turn it lowers the idle, the other way raises it.
I was having similar problems, and did all this stuff this past weekend. My car idles very smooth when warm now. When it's cold, it still jumps around a bit, but as I understand it, most CA's do that. Also, just make sure your car is in tune.
