wingFeather »
https://forums.nicoclub.com/wingfeather-u30900.html
Mon Jun 02, 2008 5:55 am
OMG NOOOOOOoooo!!!!!!!!!!!!!!! Please don't do attempt the procedure listed above. Do not ride the brakes.
Basically you want to brake hard, almost coming to a complete stop, but never riding the brake pedal and never keeping you foot on the brake when coming to a complete stop after heating them up through cycles like this.
Here is a better explanation, direct from Willwood:
PAD BEDDING
... To bed-in your brake pads, begin by applying the brakes at low speeds to assure proper system operation. On the race track or other safe location, make a series of hard stops from moderate to slower speeds. Gradually, increase the speed and the braking until the pads reach a hot racing temperature. If your car has brake cooling ducts, you may want to close them to hasten the process. If any brake pad fade is experienced during the bed-in, immediately begin the cool down process. Drive the car at slow to moderate speeds while the pads begin to cool, and be sure not to drag the brake pedal. Pit or park the car with minimal brake use and allow the brakes to finish cooling ...
