Nissan Rogue Water through exhaust pipe
neeleshapatil
Car: Nissan Rogue SV
Hi
I am a new driver and don't know much about internal working of a car. I got the Nissan Rogue SV recently and observing that its discharging water through exhaust pipe when forgot to turn off ignition and car was in Parking mode. I am observing this now frequently whenever vehicle in parking mode but ignition not switched off. See attached picture
Is this normal and something I should be worry about it ? Please appreciate your inputs here.
Does Nissan local dealer can help to check and resolve any issues with transmission?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Moisture out the exhaust is normal, one of the products produced when combustion occurs.
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
It's likely just unburned fuel. Perfectly normal when an engine is running at idle. Especially so when first started and not yet at normal operating temp.
Don't sweat the small stuff.
neeleshapatil
Thank you all for your response.
Lone Wolff wrote:
Tue Oct 13, 2020 1:17 pm
No. Unburnt fuel is called gasoline, and doesn't come out the tailpipe. That would be an instant emissions failure and a huge environmental problem.
It's condensation, which happens when the pipes cool down and consolidate accrued humidity from the air. That's why there's typically a little weep hole in the muffler. When you restart the car, exhaust gases blow the accrued water out of the tailpipe.
But correct - Not a problem.
Return to “Rogue Forum”
