NISSAN ROGUE chrome window kit
TRANCEBOY
Car: Rogue SL
Thought id share this with you guys
im not into the chrome molding around the windows
stumbled on to this kit but its not cheap
http://www.shopsar.com/nissan-rogue-chr ... p28535.htm
EddNog
Car: 2008 Nissan Rogue SL AWD
That's the kit that I currently have on my car and am actually getting removed/swapped out because of poor fitment (the pieces are catching between my passenger side doors and making it difficult to open the front passenger door, especially from the inside). The thin parts around the perimeter are clearly of mediocre, laser-cut quality compared to the pillar posts, which has rounded edges, and the design itself leaves much to be desired as a properly designed kit would make the perimeter section whole without running into the pillar posts--the perimeter section is clearly an afterthought compared to the pillar posts. Subjectively, I thought I might get used to the exceptionally wide swatchs of chrome that the pillar posts produce, but in the end I simply cannot get used to it, so all in all I've decided to remove the kit and replace with something much more subtle. Should have my car back in a week or two with this and other modifications done.
Btw, it is cheap, quality-wise. It's not cheap price-wise.
-Ed
Return to “Rogue Forum”
