Nissan Rogue 2021 Rear Left Door Glass Channel damage.
2021SV2.5
Car: 2021 Nissan Rogue
2005 Nissan Titan
Hi Nissan community.
Nissan Rogue 2021 Rear Door Glass Channel damage.
According to Nissan mechanic it is an electrical tape and do not belong there. He just removed it.
It should be replaced with a new glass channel? The car it is in warranty.
https://photobucket.com/u/levik136/p/00 ... 739c5bfbac
https://photobucket.com/u/levik136/p/34 ... 01cbed6404
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I don't subscribe to PhotoBucket and can't view your pics. Maybe you need to public them, or you can just post as attachments.
2021SV2.5
2005 Nissan Titan
I tried to post like an attachment it gives me an error.
VStar650CL
Technical Expert
Try downsizing the pics with PhotoShop or some other graphic editor. The attachment function doesn't generally like pics over about a meg in size. I find reducing to about 1500 pixels on the long axis gives you an attachable pic that still has good viewability.
2021SV2.5
2005 Nissan Titan
I tried with 250 and 105 kb and still error. I tried with add attachment button or drag the file to the message and still error.
2021SV2.5
2005 Nissan Titan
format jpeg and png still error
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
We are currently experiencing technical difficulties with the image attachment feature.
How to upload pictures on NICOclub: Using IMGUR
2021SV2.5
2005 Nissan Titan
It is better this way ?
Reason: Fix Links
VStar650CL
Technical Expert
That worked. I'm not even sure what I'm looking at with that second pic, but the first one appears to be a piece of assembly tape left over from the factory. It's used to help the channels slide in cleanly but they're supposed to remove it after installation. I doubt it damaged the channel, but post a pic with the window down. If the channel is visibly distorted in any way or the window doesn't operate smoothly because of a bump in it, then it should be replaced. Otherwise there's no reason to replace anything.
2021SV2.5
2005 Nissan Titan
The second pick illustrates that it moved up and down with the window.
2021SV2.5
2005 Nissan Titan
This is the unaltered one
2021SV2.5
2005 Nissan Titan
Rogue One wrote:
Fri Nov 03, 2023 8:33 am
Thanks a bunch. :dblthumb:
VStar650CL
Technical Expert
2021SV2.5 wrote:
Fri Nov 03, 2023 9:34 am
I don't get that either, I just uploaded an attachment to another thread and it worked fine. Weird.
:confused:
Return to “Rogue Forum”
