Nissan Rogue 2016 ECU Pinout
lis5662
Car: Nissan Rogue 2016 SV AWD
Hello guys!
I need help with my Nissan Rogue 2016 SV AWD.
May be any one know where I can find ECU Pinout for QR25DE engine ?
I need to connect my device to crankshaft position sensor, but I do not understand which wire is responsible for crankshaft position sensor.
If any one know or have pinout for QR25DE please help me.
darylzero
Here it is for the 2009 model. Don't know if it's the same or not
lis5662
Hello, thank you so much. I will check it and reply with result
lis5662
On my ECU I see 60B like on ECU Pinout image
Will check it in Saturday
darylzero
great, let us know how it goes.
zengshengliu
Car: 2008 Nissan Rogue SL
Is it just me or is the picture and the FSM upside down? So the circled pin is actually incorrect. (Fat pin on the left on your ECU image, but the FSM shows the fat pin is on the right)
Also, according to the 2016 FSM (https://www.nicoclub.com/FSM/Rogue/2016%20Rogue/EC.pdf), EC-89, the crankshaft position sensor is pin 70 and 71 (G2 and G3 according to the letter on the ECU)
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
No way would I assume that the pinout for one year was the same next year...........and over that span of years it should be impossible.
Yes, the terminal layout is upside down in relation to the pic.
lis5662
zengshengliu wrote:
Thu Oct 18, 2018 9:18 pm
Hello, thanks for help. Yes ECU is stand incorrect. I will check that new ECU Pinout from 2016 with my friend and let you know about it.
I hope that now everything should be the same like one the pictures. Because we try cut wires from previous Rogue model year ECU Pinout.
Thanks to all who help me. Will get back soon with answer.
lis5662
Hello, thank you so much for your help with this information. I have already connect my device. All is good now :)
Return to “Rogue Forum”
