Nissan Rogue 2010 wont start
spindary
Car: Nissan Rogue
Hi
my car faced an issue when i try to switch on the car is won't working especially morning (or when it is cold )
and some times is working by trying 3 or 4 times
we checked the:
feed pump is ok
crank sensor is ok
cam shaft sensor is ok
battery is ok
plugs are ok
feed pump fuse is ok
kindly need your recommendation about it
thanks
BR
Reason: Moved to correct forum area
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
1. are you using the key or remote?
2. have you checked your battery cables?
3. do the headlights work while the car wont start? (if not, its a battery connection issue)
how many miles? how old is the battery?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
You mentioned that you "checked" multiple items. Did you actually have these parts tested, or was this just a visual inspection? Places like Advance Auto Parts will check the alternator, starter and battery for free.
Return to “Rogue Forum”
