Nissan Rogue 2010 no reverse after replacing valve body
NumeroSupremo
Car: Nissan Rogue 2010
Vehicle moves forward
Vehicle does not go backwards.
Vehicle throws codes related to accelerator pedal position sensor.
I didn't work on that so I am stupefied.
I have checked the service manual and it seems to me that two things could be responsible for this state of affairs.
Failure to replace transmission lip seal ( A MUST)
Failure to reprogram the TCM
Are these ideas on the mark?
Any and all advice would be appreciated.
NumeroSupremo
darylzero
None of those pictures work.
Why did you replace the transmission valve body?
Nissan doesn't even replace those, they just give you a whole new transmission.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
Depends on what the lip seal seals. Most destroy removing them so there.
'Vehicle throws codes related to accelerator pedal position sensor. I didn't work on that so I am stupefied.'
If the ECM expects the car to move in reverse and it doesn't it may easily assume the accelerator pedal is not working.
Beyond that the complete lack of post clarity explains much there, if the work got approached in the same haphazard way.
NumeroSupremo
So sorry about the dead links
pictures in this shared folder
https://www.dropbox.com/sh/e00buis23mu1 ... wEf-a?dl=0
P1777 caused me to replace the stepper motor when that didn't clear the code, I replaced the entire valve body
NumeroSupremo
amc49 wrote:
Thu Sep 06, 2018 3:32 pm
Initial code was P1777.
I ran the full gamut of checks from the service manual and it was very clear we had a bad stepper motor
So I purchased and installed just the stepper motor into the initial/original control valve
The initial code P1777 did not go away, instead it stayed back and it brought along with it a bunch of additional codes related to the accelerator pedal position sensor - to be particular, these codes:
P2122
P2127
p2138
There are only two procedures in the service manual that I have not so far followed...removing and reinstalling the lip seal, see pictures
https://www.dropbox.com/sh/e00buis23mu1 ... -26-30.png
and
https://www.dropbox.com/sh/e00buis23mu1 ... -27-20.png
and
https://www.dropbox.com/sh/e00buis23mu1 ... -27-47.png
the second procedure that I haven't followed is...inspection after installation
https://www.dropbox.com/sh/e00buis23mu1 ... -31-17.png
this is all the relevant information I could find on the open internet on lip seals and transmissions: https://www.freeasestudyguides.com/auto ... seals.html
I am available to provide any further clarification..sorry for the brevity of the initial post
NumeroSupremo
darylzero wrote:
Thu Sep 06, 2018 3:14 pm
Thanks for the observation..fixed, see dropbox link https://www.dropbox.com/sh/e00buis23mu1 ... wEf-a?dl=0
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
If you have less than 120k miles on your vehicle Nissan has an extended warranty that covers replacement of the transmission. You may want to at least check it out.
Of course now that you’ve attempted repair yourself Nissan may use that as an excuse not to cover any repairs. I think there is also a time limit on the warranty but I’m not sure how long.
Return to “Rogue Forum”
