Thanks for the info. Yeah the picture I provided is wrong.
The switch is a latching which does have nighttime back lighting and power indicator.
This is what I've been able to figure out so far:
Switch wire #1 red is for the fog symbol/nighttime lighting.
Switch wire #3 red is for the power indicator.
Switch wire #4 black is ground.
Switch wire #2 green, I am guessing is going to supply power to a light I want to hook up.
In regards to the relay you are correct in that the image supplied is wrong.
The existing wiring to the relay:
Connectors # 2,7 and 6 are ground
Connector #3 has 3 wires going to it. One is for incoming power, one is going to light, the 3rd one is going to the switch.
The yellow wire from connector #5 and the white wire from connector#1 are suppose to go to the switch but not sure to what.
What I am hoping to do is the following:
Only when the car is on, I can press the switch and turn the light on . When I turn off the car, the relay will deactivate the light switch until I turn on the car again.
