I'm in the process of rebuilding the rear calipers on a 1993 240sx and I purchased the oem nissan seal kit. The confusing thing is that the kit for the rear calipers came with 2 grease packets. The instructions say use red colored grease on the piston seal and the orange on the surface of the slide pins. If you look at the image below, I have like a blood orange and pink packets of grease. They didn't even label what kind of grease it was so I can't really compare them to the diagram in the FSM.
Has anyone done a rear caliper rebuild using the nissan kits and know which grease goes where?
