Nissan Quest ring replacement
sh820
Car: 1994 Nissan Quest
Hello - My Nissan van has low compression on #1 cylinder - and all the symptoms of a blown ring. I would like to repair it without pulling the engine. I am looking for advice before getting started. Thank you
NolimitZ32
never done it on a quest however it will require you pulling the piston/rod in question out of the engine, if you have access enough to remove the oil pan you may be able to get the rod of and massage it out. However putting the piston back in may be near impossible.
sh820
Thanks - the oil pan is fairly easy to remove on this car. It is a v6 - the piston in question is facing the firewall - but I believe there is enough rome to remove it.
NolimitZ32
Like I said removing it wouldn't be the hardest part, getting it back in the bore with the new rings will likely be the hardest part.
Razi
Car: Moo
You'll need to remove the head and the pan, then install the piston with new rings.
sh820
Will there be enough rome to remove the back (cab-side) pistons with the engine still in the vehicle? Thanks
NolimitZ32
That I cannot answer, I've never gotten that deep into a Quest.
TTkickedin
Car: 1991 Nissan 300zx TT 5 speed, t-tops, < currently in intensive care unit!
2011 MBTA BUS
NolimitZ32 wrote:Like I said removing it wouldn't be the hardest part, getting it back in the bore with the new rings will likely be the hardest part.
Your answer.
You might be able to, but chances are high that it won't work.
*ps* I actually asked my friend this. He's into Honda's (never worked on a quest.)
He told me that on B series engines, he usually would just take the heads off and oil pan and pop the piston out from the top if he didn;t have enough time to get the engine out.. Razi already mentioned this.
You're welcome to try. Please tell us if you fail.
sh820
I am going to try to pop the head and pan of and see if it works. I will let you know how it goes.
TTkickedin
2011 MBTA BUS
If you do take the heads off, that "will" work.
but as far as just taking it out through the oil pan, that would be a no, sir.
By the way, make sure there's enough room for you to reach your hand into the crank and push the piston up the cylinder, it would be literally impossible to just pull the piston out from the top, there's no handle :gapteeth:
