Thank you so much for your response. I'm not planning to take out the pan. Just drain and fill this time. Do you recommend draining and filling (and checking level) while car is cold or hot? And am I looking for the oil to be between the notches on the hatch area?VStar650CL wrote: ↑Mon Apr 28, 2025 4:10 pmIf the stick is accurate then it's way overfull, and the '13's did come with a stick so chances are it's accurate. However, make sure you're reading it right. One side of the stick will always read higher than the other because of the entry angle, and the lower side is the correct one to read. You also can't trust the stick right after adding fluid, it tends to adhere to the tube sides and mess up the readings. Give it a couple minutes between check-and-adds.
The '09B CVT's generally take right around 4 quarts, but I'd have 5 on hand. If you're dropping the pan, the big thing to watch out for is aftermarket filters. Many parts stores have the '09A screen listed as interchangeable with the '09B, but that's wrong. The '09A had a deeper pan than the '09B, so using an '09A filter will bottom the pickup against the pan. That will cause the van to not move after you button up the pan, because the pickup will be blocked. Check the thickness of the new screen assembly before installing it, if the new one is taller then return it for the right one.
Thank you! Does it matter if I use Valvoline CVT compatible with NS-2? The thing is, it says on the bottle that it is NS-2 and NS-3 compatible. I'm not sure how that works.VStar650CL wrote: ↑Mon Apr 28, 2025 7:36 pmStick checks should be done running and preferably warm, they're less accurate when cold. On most Nissan sticks the hatches are warm and the notches are cold, but whichever set is higher on the stick will be the warm marks.
Thank you!VStar650CL wrote: ↑Tue Apr 29, 2025 5:27 amI've never seen any miscibility issues between fluids as long as they claim NS3 compatibility. NS3 is downward compatible with NS2, so you can freely use NS3 in an NS2 transmission and all the aftermarket NS3's I'm aware of also claim compatibility with NS2. Your '13 Quest takes NS2 so this doesn't apply to you, but for the benefit of others, NS2 is not upward compatible with NS3 and shouldn't be used in an NS3 transmission.
Thank you! I'm changing it now.VStar650CL wrote: ↑Fri May 02, 2025 7:52 amNope. That's conventional wisdom about conventional A/T's, and it's correct in that context. Conventional A/T's eventually make "ATF soup" from used-up clutch material, and often that's the only thing keeping the seals together. So basically you run it till it breaks because a fluid change may kill the Valve Body.
ABSOLUTELY NONE OF THAT APPLIES TO CVT's. CVT's have almost no clutch material and thus have no ingredients to make ATF soup. However, the belt and pulleys are metal-on-metal, and the only thing preventing metal from meeting metal is the quality of the fluid. So the CVT equation is much different from a conventional A/T... when the fluid dies, the transmission dies with it.
In a word, change that s#it ASAP.
