Nissan Quest 2002 Reverse Wire
A forum for the Nissan Quest... minivan lovers unite!
undersworld
Car: Nissan Rogue 2013
Hi - I'd like to install a backup sensor and backup camera to my bother Quest 2002...so my question is which is the reverse/reverse light wire?
012620
Car: 2012 Nissan Quest SV
On a 2012 Quest I installed a backup beeper. Check the wire loom in the rubber case back door hatch top left. I used the yellow wire which on the 2012 is the backup wire. Might be the same on yours. Check with wire tester lite first. Good luck. :)
Return to “Quest Forum”
