what if u get an RB26DETT since the pathfinder already comes with a 6 cyl. i dunno i think it would be alittle wierd if i saw a 4 banger r50 pathy. but man do what you think is bad a$$ because it is your money.TJcars2 wrote:The weight I'm not too concerned about. The car is only about 800 some pounds heavier than the S14 Silvia. Plus when you swap out the motor it will be lighter cause it's smaller. I'm also lightening the car and I'm planning on topping the motor out around close to 400 HP.
