sicwitit »
https://forums.nicoclub.com/sicwitit-u90139.html
Thu Jan 07, 2010 3:31 am
the video looks more like a vacume leak.
one way to test for a vacum leak, get a bottle of brake cleaner, open hood, turn on engine, spray brake cleaner on hoses, manifold nipples, gaskets, and anything after the MAF that has air in it before it gets to the combustion chamber. if you have a leak, the brake cleaner will make your engine idol go up for a sec. then you know where your leak is.....if you have a leak that is..
Oh and be sure to use the straw to better aim your spray, that comes with the bottle.
post your results.
