Pathfinder / QX4 Reliability (Post your mileage)
p598738
Car: 1999 Infiniti QX4 160K miles
1999 191K. Just did the timing belt. Never sees bad weather. Maybe another 191K !!!
p598738
Oops. It's a QX4. Did shocks and struts. 30K maint et al. Budget $1000 per year to fix and maintain. Timing belt was $750 here in Maine.
Steelersfan745
Car: 1997 QX4
2001 QX4
2013 Leaf SL
1997 QX4 with 246K. No major issues to report. It doesn't see as many miles as it used to as I bought a Leaf last year and that has replaced the QX4 as the daily driver.
path01
182500 2001 LE. Biggest thing was entire computer was replaced for $2,000 year ago. Other than that just regular maintenance. But now dealing with P1140 and squealing at start. If anyone in Portland/Beaverton area wants to help me not throw away my money id be grateful.
Fastbiker
Car: 2001 qx4
2001 QX4 just turned 272,000 miles and running like new. No major issues to date.
RR425
Car: 2001 Infiniti QX4
Fastbiker wrote:
Tue Sep 05, 2017 1:34 pm
That's great to see. My 2001 has almost 170k miles and I hope it has another 170k in it. Have you replaced the water pump? Preventive maintenance? Besides rebuilding most of the suspension I've only replaced the alternator and spark plugs on mine.
BryanSV
Car: Pathfinder 2002 LE version
:) :naughty: Hey everybody!
I just recntly acquired a beautiful Pathfinder 2002 with nearly 150k miles on it
I havent checked oil, plugs or any other major components, i know it runs nicely cause the shocks and brakes are neat
On the road above the 80mph it tends to move to the right and left like if it is swaying slow (so not sure what to check right here)
My question is: What do you recommend to me to do asap in order to make it gallop another 100k miles more?
Thanks in advance!
I can post pictures later :)
Ozimandius
Car: 2001.5 Infiniti QX4
Just bought a '01 QX4 with 4WD, with 225000 miles.
RR425
BryanSV wrote:
Sun Nov 12, 2017 10:16 pm
Rear control arm bushings. I replaced mine with polyurethane from 4x4 parts (I think that's who it was).
Did it myself but had to get a impact wrench to get the bolts off.
Fetner
Car: 2003 Infiniti QX4 4WD
Just got a 2003 QX4. 182,000 and going strong. Has a slight issue with a rumble/vibration between 57-70 mph and 2-2.5k RPM.
smokeeater84
Fetner wrote:
Sun Nov 19, 2017 7:43 pm
Did you ever find the issue for the vibration. I am getting the same issue.
Deplorable
smokeeater84 wrote:
Sat Dec 16, 2017 4:41 pm
First post in this forum. Just picked up a 01 QX4 4WD with 180k miles. Seems to be running fine. Did throw a service engine soon light so need to investigate, and I do get the shimmy from about 57 to 70 mph as well. I was assuming tire balance.
1beastnstl
Car: 2011 Nissan Armada SL
Good to see high mileage trucks going strong.
Saabjock
Car: 2003 Nissan Pathfinder
2003 Pathfinder 4x4 Auto SE....198000
brickbox
Car: 2011 Nissan Pathfinder 4x4
02 QX4. Creeping up on 155k miles. Needed rear brakes, shocks, VCGs, balancing of drive shafts, front wheel bearings. Outside of that, it was mostly catching up with maintenance items that had been neglected. Oh, and fixing that adaptive cruise control system!
Car: 2001 Nissan Pathfinder LE
01 LE , jus hit the 300,000 KMS (186,411 miles) knock on wood running like a new car not a thing wrong with it. I baby it and its a work vehicle and im mobile :P
NolaNissanMonkey
Car: 1999 Nissan Pathfinder XE
1999 Pathfinder with 225k.
She still runs like a top
PF17
Car: 2006 PF
My 2006 PF LE has over $225,000 miles on it. Just had it’s first tune up! I believe I can get over 300k.
tophatl
Car: 2001.5 Nissan Pathfinder LE
1973 Datsun 620
2001.5 PF LE with 205k on it (and counting). Had it over the past ~35k. Nothing too major- had the oil cooler leak (easy fix) and sporadic overheating issues (removed swirl valve/second thermostat, main thermostat, replaced radiator and unclogged rear bleed pipe). I still need to replace the rear trailing arm bushings and replace the valve cover gaskets. RMS is leaking too, but hoping HM oil stops that. No rust!
Micallen
Car: 2003 Nissan Pathfinder SE 4x4 V6
2003 Pathfinder SE 4x4 with 140K miles. Runs good. I too had the shimmy at 60-70 MPH, but tires were terrible when I bought it. New set of tires (and balance, of course) took care of it. The only real issue I have with it is the water leak (seems to likely be coming in around top/left on driver's side).
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
My 2001 Q just hit 256xxx miles.
I've had it since about 2011 which was at 126xxx miles.
My reverse gear just gave out, so my miles are going to stop here :(
Rockwood
Car: 2002 QX4
That is too bad. But 256k is pretty darn good! You could always buy another used one - they are priced pretty reasonably at this point. You'd have lots of free spare parts!
PathyPop
Car: 2003 Nissan Pathfinder LE 4x4
donald wrote:
Tue May 15, 2018 10:15 pm
Been there long ago. Think ahead and you can get by without it. Maybe an occasional push, just don't park down hill.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
202,000 miles on my 98 QX4. I few little things here and there, but it's still running strong!
ianh
Car: 2018 Nissan Pathfinder SL Midnight Edition
1997 Nissan 200SX SE-R
2003 SE 4WD
Owned since 2004.
Not mush other than regular maintenance and AC compressor about 130K.
156 K miles, new starter , had hot soak problem
and then Transmission failure on a trip.
So its gone.
amm203
2008 Subaru Legacy GT
Just recently purchased a 2003 LE Pathfinder 4x4 with 163K miles. Engine appears to be in very good condition (no ticks or odd sounds) - the previous owner was meticulous with service intervals and history (mostly - see below). Being a rust-belt vehicle in Western PA I'm surprised how good the body & undercarriage condition is for a 15 year old car.
So far I've done some maintenance and additions;
- Front sway bushings, air filter, spark plugs, cleaned MAF & throttle body.
- Plan to do front end-links, steering rack bushings, rear bushings/end-links, rear shocks (KYB Gas-A-Just) and the oil cooler gaskets - it's a mess under there. This website has already been incredibly helpful (spark plug walk-through especially).
- Added a Pioneer AVH-3300NEX in place of the Bose system. In the end the wiring was not that difficult and install was a breeze. The addition of Apple CarPlay is awesome.
Only thing the previous owner never did was spark plugs (thought they were a lifetime part). After pulling the plugs I could not believe there weren't any misfires. Plugs were worn down to the thicker part of the electrode (no tip whatsoever). The gap basically doubled. It's apparent these engines are damn good.
This vehicle will be primarily used as a winter vehicle. I plan to garage my 2008 Legacy GT during those months and couldn't be happier with the purchase. These cars look and perform great for being 15 years old - very happy to be part of the NICO community!
Nefara
Almost 205,000 on my 2001 Infiniti QX4. Have had to replace oil filter, fuel filter, air filter, light bulbs, and tires. Need to replace the spark plugs soon. No sensors yet and hopefully not for a long time. Still original parts other than listed. :werd:
R3.
Car: 2002 QX4
Right at 540,000 miles on a 2002 QX4. Nothing other than basic maintenance until now. Reverse suddenly disappeared - no warning whatsoever. Hoping that it's something simple.
ianh
2003 SE 4WD owned since 2004.
Transmission died on trip at 159,900.
very good otherwise. Was hoping for 250k !
jamesrenn
Car: 01 Infiniti qx4 3.5L V6
01 Infiniti QX4 185K miles and runs perfect. No major work done at all, only preventive maintenances.
