Hello Nico! First post here as a member, here's some detailed info on my Pathfinder:
1997 Nissan Pathfinder SE 4x4 - Manual trans
Current mileage: 225,000+ (362,102 KM)
Background
I bought this Pathfinder SUPER CLEAN at 161,000 on the odometer. Not so much as a scratch on it, interior/exterior was tight. It was a dealer car for the first 70,000 miles of its life. Second owner was the brother of the guy that worked at the dealership, sold it to me saying it "was the best car he ever owned."
The first 10,000 miles this car ran like an absolute top. Then at 171,000 things started falling off. Since its been about 3 grand a year in maint to keep it on the road. Here are some of the issues/maint I have done out of necessity.
- Blew a front radiator hose. Replaced all hoses and basic belts. Hoses are a serious job on this truck and they're are a lot of them, if you're being thorough.
Original starter went out at 170k
Original alternator went out about the same time, 170-175k
Cracked the radiator overflow bottle, replaced.
MAF sensor went out, about a $300 part, easy DIY repair.
Charcoal canister disintegrated, expensive to do at a garage because there was charcoal in the lines. Do yourself a favor and when you throw that EVAP code, fix it right away instead of driving on it for 10k like I did.
Radiator replaced around 215k
Timing belt and water pump replaced at 210k
New rubber at 190k
Spark plugs, wires, cap and rotor done at approx 190k
Brake shoes at 170k
Clutch replaced (almost certainly the original) at 219k!!
Stock Bose stereo swapped out for Pioneer headunit
a single O2 sensor replaced.
Passenger side electric window switch replaced (easy ebay diy)
Its been a rock solid ride, although I would like to get 6-8 months in without having to drop a grand on something, which is the pattern. I plan on driving it until at least 260,000 if I can make it without any major engine problems. Currently I have a some sort of a suspension issue that is causing it to drift and it seems out of alignment all of a sudden. Feels like suspension. I'm taking into the shop tomorrow for a look see but I've been coming on these forums for years now for good intel and boooy there is a lot of it. Congratulations on a great community! Happy to add to it. Cheers all!
