Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Thu Aug 11, 2016 10:48 am
Lol, thanks EdBwoy!
Yeah, in terms of 5-lug conversions, it will be very difficult without just using the adapters you're already aware of. The reason it's difficult is because:
1) For the front, you'd have to find a suitable donor vehicle with a wheel hub that would fit. Ideally, this could be accomplished with wheel bearings that have the inner diameters to match the OE spindle, and the right OD to match the donor hub. But this approach would require a fair amount of research because you'd also have to match up ABS sensor/ring position, account for the overall thickness of the bearing packs, and possibly make modifications to the disc brake setup.
2) For the rear, you could always pull the axle shafts and have them drilled to the bolt pattern...there are a few companies that can do that...but then you also need to have it done to the brake drums (although they might need to be re-balanced when done).
Bottom line is that it's complicated to do without having a suitable donor to make it bolt-on-ish. Nissan had a few vehicles where this was relatively simple (the 240SX models, for instance), but it's not the case here. Even if you took the approach above, the cost would likely be unreasonable.
Though, I'm surprised you've had difficulty finding suitable wheels in the 6x5.5 pattern. Toyota and Chevy trucks share the pattern, and I've seen no shortage of options there. If there's a certain stance or tuck you're looking for, do you know what offset or backspacing you need?
