OzzyE »
https://forums.nicoclub.com/ozzye-u208637.html
Wed Aug 22, 2012 7:35 pm
I have changed all spark plugs very carefully at 105000 miles, On my way to work s.e.s light came on and stay on, took it in to the dealer and diagnostic code reads P1130 swirl valve solenoid is inoperatable" estimated cost to replace is three hundred+tax. I unplug the two fine black hose that one connect to the air filter canister and the other to the little round black thing, but I guess I should not have unplug the fine hose, cause those two hoses leads to the swirl valve solenoid switch. Don't know by unpluged the hoes if regular air from in my garage can cause the swirl control valve to go inoperatble.????
