Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Tue Jan 07, 2014 3:58 pm
First, try running two 20oz bottles of Chevron Techron Fuel System Cleaner, one in a tankful for two back-to-back tanks. This may help with your P0430 code.
For the death sway, the rear trailing arm bushings are at fault, correct. There are a total of eight: two per arm, and there are two arms per side, upper and lower. Inspect all of these to see if any are disintegrated and if any arms have excessive play.
You can either have a shop press the bushings in, or you can replace the entire trailing arm assemblies; new ones come with bushings, of course.
For the start issue, ensure the battery terminals are tight (but not overly tight; too tight cracks the battery terminals and leads to unstoppable corrosion) and corrosion-free.
Do you have more codes other than P0430? If so, post them here.
Welcome to NICO!
