elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Dec 02, 2006 8:23 am
Welcome to NICO!
For the fluid, the manual calls for a GL-4 gear oil. as long as its GL-4 and ONLY GL-4, the minor difference in viscosity ratings doesnt mean much.. Ill give you an example... IN my differential it calls for GL-5 80w90, however, im currently running a 75w140.. It works perfect, however if i was to use a GL-4 (or anything else other than GL-5) it would be a bad idea, regardless of viscosity!
I dont think that the oil change (its not a flush on an MT, just a drain/refill) had anything to do with it, however, im also not a believer of coincidences....
Im wondering if you just need to have it adjusted... Even so, $1000 for a clutch replacement does sound a bit high, thats something that most shops should be able to do... not really anything special about it on the pathy vs any other truck...
